ssl SVC routing table
Jul 3rd, 2007
Hello, The user is authenticated, connected....and then we get the message: Unable to successfully verify all routing table modifications are correct.
I found a bug that said if local lan was checked and if you have two network cards and one doesn't have an address, you get that message. Surely, there is something else. We have tried this on laptops with wireless and lan and no IP on the lan and it worked fine.
Any other documentation on troubleshooting Cisco SSL?
Jim Cornelson
Processing CSTP header line: 'X-CSTP-Hostname: MEGSCOMPUTER'
Setting hostname to: 'MEGSCOMPUTER'
webvpn_cstp_parse_request_field()
...input: 'X-CSTP-Accept-Encoding: deflate;q=1.0'
Processing CSTP header line: 'X-CSTP-Accept-Encoding: deflate;q=1.0'
...input: 'Cookie: [email protected]@[email protected]
6C6F0B87357'
Processing CSTP header line: 'Cookie: [email protected]@[email protected]
B5B23EDE6DFAE7DB63F6C6F0B87357'
Found WebVPN cookie: [email protected]@[email protected]
63F6C6F0B87357'
WebVPN Cookie: [email protected]@[email protected]
F0B87357'
Validating address: 0.0.0.0
CSTP state = WAIT_FOR_ADDRESS
webvpn_cstp_accept_address: 192.168.128.1/255.255.255.0
CSTP state = HAVE_ADDRESS
SVC: NP setup
webvpn_svc_np_setup
SVC ACL Name: sslcsvpntunnel
SVC ACL ID: 4
SVC ACL ID: 4
vpn_put_uauth success!
SVC: adding to sessmgmt
SVC: Sending response
CSTP state = CONNECTED
webvpn_rx_data_cstp
webvpn_rx_data_cstp: got message
SVC message: t/s=3/17: Unable to successfully verify all routing table modificat
ions are correct.
dsweeny Mon, 07/09/2007 - 13:50
If you establish an SVC connection with a remote computer running Windows XP using the DHCP Alternate Configuration, the SVC fails to connect and fails to update the routing table
