OSPF Peer Limitation
Jul 3rd, 2007
I need that information if it is available:
How many OSPF peer does Cisco router support? For example; Cisco 7206VXR
router supports how many OSPF peer on its one of the ethernet or serial
interface?
Tansel Akyuz
Network Engineer
TUVTURK
mounir.mohamed Tue, 07/03/2007 - 23:22
It's depending on allot of verities for example the OSPF router may have multiple point-to-point interfaces into different areas or the same area (As per Cisco recommendation the router should not belong to more than 3 different areas) I the same time the router may be elected as the DR on the Ethernet segment so finally it?s deepening on the router resources.
Best Regards,
Mounir Mohamed
royalblues Wed, 07/04/2007 - 01:21
Welcome Mounir... good to see you back in the forum
Yes i agree with Mounir that it totally depeneds on the router resources.
These are however some Cisco OSPF design recommendations
routers per area - 50
neighbors per router - 3
areas per router - 3
Bit again this may differ according to your network topology and traffic patterns
Narayan
inzeos781 Thu, 07/05/2007 - 05:25
You could also consider forcing your down stream routers to only create two adjacencies with the DR and BDR to speed up convergence.
