Problem active to balance between two equipment
Jul 3rd, 2007
Model: CISCO WS-C6509 Description of the problem: We have trunk qualified between the equipment cpdv_01 and cpdv_02. Trunk has a connection main in the FastEthernet8/19 interface and secondary in the FastEthernet9/38. The problem is that they are balancing the traffic, and leaves a similar amount in both interfaces. We opened this consultation to them so that they confirm to us if this is normal and that to make to avoid it.
cpdv_01#sho run int gi8/19
Building configuration...
Current configuration : 297 bytes
interface GigabitEthernet8/19
description trunk2a_telefonicasa02
no ip address
speed 1000
duplex full
no snmp trap link-status
switchport
switchport trunk allowed vlan
1,2,5-7,12,13,15,20-28,33
Amit Singh Tue, 07/03/2007 - 23:48
Please explain your problem in details.. its very hard to understand the problem that you are facing with the above explanation..
-amit singh
