HSI rejects incoming calls from H323
Jul 3rd, 2007
Network sheme:
ss7network-> as5350-> PGW2200 (v9.4.1)->
-> HSI(4.1)-> H.323 network
Calls from SS7 to H323 network are completed successfully. But if i try to make call in back direction, from h323 to PGW2200 i getting "No_route_to_destination" from HSI. Where is the bug?
Does Cisco_HSI analyse B-number?
How can i fix this problem?
Thanks!
akutra_oss Thu, 07/19/2007 - 09:22
traffic goes normally from SS7 operators to HSI and then to H323 network.
The problem only in back destination.
Chester Rieman Thu, 07/19/2007 - 09:46
  • Cisco Employee,
Right...For the incoming H323 setup in question, do you see an outgoing IAM on the SS7 side? If you see an IAM go out for this call, that means wherever you are sending the call is sending back the release. If you don't see an IAM go out, the issue is with the PGW configuration.
