Console Hashed password
Jul 4th, 2007
i configured a password for the console port and it is encrypted with password 7 , is it possible to configure a hashed password like secret 5.
Talal Habeeb
Amit Singh Wed, 07/04/2007 - 00:40
  • Cisco Employee,
Yes, you can do it.
Configure a username and password with enable secret on the device first. Like
Username Cisco secret abcdef
enable secret cisco
Then configure the line console to use a local authentication:
Line con 0
login local
this will force the user to use the secret password defined for the profile.
HTH,Please rate if it does.
-amit singh
