Warning message
ios file reqd which supports bgp
Jul 4th, 2007
i have an ios file "c2800nm-ipbase-mz.124-3g" for c2851 router.its not supporting bgp .i need an ios file name and ios for c2851 which supports bgp,version 12.4()3g).this is an urgent requirement
Overall Rating: 3 (2 ratings)
Jon Marshall Wed, 07/04/2007 - 00:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The easiest way to do this is to use Cisco's Feature Navigator Tool. Had a look for you
Advanced IP services supports BGP
c2800nm-advipservicesk9-mz.12.4-3g.bin
as does
Enterprise Services
c2800nm-entservicesk9-mz.12.4-3g.bin image
Jon
kp_prasanna Wed, 07/04/2007 - 01:00
hi,
thanks,do u have any ways to download the ios file
c2800nm-advipservicesk9-mz.12.4-3g.bin .i don't have cisco cco login.
Jon Marshall Wed, 07/04/2007 - 01:16
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Unfortunately it's not as simple as that. Because you are upgrading to an image with more features in it there may well be a cost involved.
You need to talk to whoever you normally deal with when purchasing Cisco kit.
Jon
kp_prasanna Wed, 07/04/2007 - 01:42
fine,how to install the ios in an router,basic steps reqd
kp_prasanna Wed, 07/04/2007 - 02:14
hi guruprasad,
thanks.in the procedure,it says
Download a TFTP server. Refer to TFTP Server Selection and Use for more information.
Configure the TFTP application to operate as a TFTP server instead of a TFTP client.
u can specify the tftp server reqd and the link to download itand the steps reqd to operate as an server.
guruprasadr Wed, 07/04/2007 - 02:27
  • Gold, 750 points or more
HI Prasanna,
"SolarWinds" - is a very good tool for TFTP Server.
You can download a Trial Version / even from http://www.download.com/3120-20_4-0.html?tg=dl-20&qt=SolarWinds&tag=srch
For step-by-step procedure to Setup an TFTP Server (as SolarWinds) - Pls refer Link below:
http://www.solarwinds.net/Toolsets/Help/AdminGuide.htmhttp://www.solarwinds.net/Toolsets/Help/TFTP-Server.htm
Pls do RATE / VOTE all Helpful Replies
Best Regards,
Guru Prasad R
kp_prasanna Wed, 07/04/2007 - 05:34
hi guruprasad
sure,i will check the links given by you.i am leaving out
thanks a lot
keep in touch
prasanna
inzeos781 Thu, 07/05/2007 - 05:30
For TFTPD server if you are running a Windows platform I would suggest;
TFTPD32, which is a free download from;
http://tftpd32.jounin.net/
It also includes a DHCP and syslog server functionality. Recommended by Cisco as well.
