CME call forward no answer question
Jul 4th, 2007
Can the default CFNA behaviour on CME be changed. For example a call to phone A is CFNA to phone B. If phone B does not answer the caller hears phone B's voice mail. I would like the caller to hear the origional phones voice mail, phone A in this case.
Colin
paolo bevilacqua Wed, 07/04/2007 - 03:02
  • Hall of Fame,
    Founding Member
Hi Colin,
once the call coverage becomes sophisticated, eg "I'm not there but the other person should anyway if we are not go to voice mail", it's better to setup an ephone-hunt. That will allow you define the order and the lenght the phones ring, and a final number eg. for voice mail.
Aaron Dhiman Mon, 11/19/2007 - 18:36
Is setting the intended vmail destination via the "final" command the only way to forward to the first list member's voicemail? That has the negative effect of extending the ringing until that user's CNFA expiry kicks in. Is it possible to just forward immediately to voicemail instead of waiting?
To further clarify, is this the best way to force forward to the 1st hunt-group members vmail on no answer:
ephone-dn 1
number 3001
call-forward noan 3333 timeout 18
ephone-dn 2
number 3002
ephone 1
ephone-template 1
mac-address 0006.D737.D08E
type 7940
button 1:1
ephone 2
ephone-template 1
mac-address 0015.6316.E122
type CIPC
button 1:2
ephone-hunt 1 sequential
pilot 3000
list 3001, 3002
final 3001
OR, is there some way to go immediately to the vmail for 3001 without waiting the additional 18 sec?
paolo bevilacqua Mon, 11/19/2007 - 18:44
  • Hall of Fame,
    Founding Member
Hi, why not sending via "final" the call to a a CUE GDM instead, of which you make member who do you want.
Aaron Dhiman Mon, 11/19/2007 - 19:52
I'd like to only direct to one phone, and I'd like to have that phone's MWI light up. I tried to do an overlay onto the primary line for the phone, with that overlaid DN set to immediately forward all to vmail, but that didn't work, b/c CUE didn't tie the extension to the primary.
Rob Huffman Wed, 07/04/2007 - 05:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Colin,
Just to ad to Paolo's good info (good job Paolo). If you are using CUE for VM;
This feature is now available in CUE 2.3 have a look;
Mailbox selection
This configurable option specifies the mailbox to be used in case of call forward. SIP phones are not supported.
From this doc;
Cisco Unity Express
Release Notes for Cisco Unity Express 2.3
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/prod_release_note09186a0080679b50.html
Mailbox selection: Mailbox in which an incoming voice message is stored. The options are original called number (OCN) or the last redirected number (LRD). LRD is the default option.
For example, suppose caller A calls user B's extension, which forwards the call to user C, who does not answer the phone. The call goes to voice mail. User B's extension is the OCN and user C's extension is the LRD. If the system is configured with the OCN option, the system stores the message in user B's mailbox. If the system is configured with the LRD option, the system stores the message in user C's mailbox.
From this doc;
Cisco Unity Express 2.3 GUI Administrator Guide
http://www.cisco.com/univercd/cc/td/doc/product/voice/unityexp/rel2_3/cue_cli/ch3sys.htm#wp1075610
Hope this helps!
Rob
ReadersUK Wed, 07/04/2007 - 08:41
Hi rob
Thanks that's a cool feature. It will solve my problem.
Also thanks to pauolo.
Ill rate you both when I get home. Not easy on a blackberry.
mark_gardner Thu, 07/05/2007 - 00:42
Hi Colin
You can do this in cme/cue with the following command applied to your voip dial peer pilot number for voicemail.
dial-peer voice 1000 voip
mailbox-selection orig-called-num
description VOICE_MAIL
destination-pattern 1000
session protocol sipv2
session target ipv4:10.10.10.1
codec g711ulaw
no vad
