07-04-2007 02:26 AM - edited 03-05-2019 05:07 PM
I have two Cat 6506 with 2 1000Basex Gbic blades each in slots 2 & 3. Can you form an Etherchannel group with ports on different blades i.e. ports 2/16 & 3/16?
Running CatOS 8.3(3).
Solved! Go to Solution.
07-04-2007 02:57 AM
07-04-2007 03:02 AM
07-04-2007 02:29 AM
As long as the ports are of same type u can form the ether-channel with ports on different blades within the same chassis.
Mahmood
07-04-2007 02:35 AM
Mahmood
Thank for that. the config would be -
set port channel 2/16 3/16 on? (Both switches).
Regards John
07-04-2007 02:57 AM
Hi John
Yes that is the right command for CatOS.
Jon
07-04-2007 03:02 AM
As Jon said the commands are correct.
Mahmood
