ADSL Annex-M Support on WIC-1ADSL??
Answered Question
Jul 4th, 2007
From what I understand to get Annex-M ADSL2 support on Cisco routers you need to get a hardware upgrade/replacement and IOS 12.4(11).
New versions of the 877 routers with a "-M" and a "HWIC-1ADSL-M" have been released for various other routers.
What I wish to know is if there is going to be any new WIC-1ADSL part with Annex M support (aka WIC-1ADSL-M).
Correct Answer by Paolo Bevilacqua about 9 years 7 months ago
Hi, I don't think there will be any evolution for the older WIC, because the higher rates require in fact the highest bus speed that only HWIC's have.
Overall Rating: 5 (2 ratings)
Correct Answer
Paolo Bevilacqua Wed, 07/04/2007 - 03:28
metalium2007 Tue, 05/20/2008 - 08:18
So in the 3700 series will we be able to use HWIC-1ADSL-M, ...surely not?
Paolo Bevilacqua Tue, 05/20/2008 - 12:58
To be honest, I can't find a conclusive document that show the 3745 supporting hwic-1adsl, let alone the -m. So if you want annex m, the safest whay would be to order a router that embedded ot hwic, supports that offically.
metalium2007 Tue, 05/20/2008 - 13:00
Paolo,
That is really really my problem. Customer needs to know to deploy in about more than an hundred locations.
In 38xx i know that i can use HWIC ports, no problem. But and in 3700? argh, what a dillema!
Thanks!
