ASA V7.2 how to deny ftp/get command
Jul 4th, 2007
I normally use the configuration below to block the ftp/get command on my ASA v7.1. But, after upgrade to v7.2, the 'ftp-map' command has been deprecated. We need to use Use 'policy-map type inspect ftp' instead. I found the only actions to ftp command are 'reset' and 'log'. But I only need to block ftp/get command, not to reset the ftp connection. How can I do with v7.2? Thanks
This is my old configuration in v7.1:
ftp-map deny_get
request-cmd deny get
policy-map global_policy
class inspection_default
inspect ftp strict deny_get
