(WEBVPN) CIFS access problem on ASA 8.0.2...
jbillochon
I've recently migrate my ASA 5505 from 7.2 to 8.0.2.
CIFS access worked in version 7.2, but since the migration, it doesn't work.
Screen stay on "downloading" status and nothing happen.
I've try some capture (by ASDM wizard et directly by Ethereal) and it seems that nothing come from the interface when user click on "share link".
Any idea ?
Thanks.
Julien
5 Replies 5
japonte
I have run into the same problem after my upgrade. I did a packet capture and found that the asa is passing the user name as anonymous to the server instead of the actual username I put in.
hi,
Welcome on board ! :o(
I'm still stuck on this issue.
Julien
cellule.reseaux
The same for me.
Any bug fix ?
No fixes yet, but there is a workaround - don't set the language to french.
There should be a fix in 8.03, which should be released soon
--Jason
