PIX 515 reloading every 1-2 weeks ,(
Jul 4th, 2007
Hello everyone !
I have 2 Pix 515 here in production, each one for an internet line.
For six month , i have serious trouble with the one connected to the bussyiest one : every 1-2 weeks it reloads itself most often at the worst moment, where hundreds of client are connected ;(
Sure it reloads fast but every connection is lost and clients are to reconect...
I have an Backup unit with the same caracteristics so i put it online ...
3 weeks after ... reload in the middle of the morning ,(
Failover is not really a solution as i don't have an free ethernet for state failover (using all 4 zones).
Tried to implement syslog but it seems to be verrrryyyy slow as my syslog server where receiving msg from the pix that were 2-3 hours late ???
Couls that be an firware issue ? I use 7.0(1) and idon't have anymore CCO access so i can upgrade to 7.22 ;(
Any idea ?
Here's the spec of one :
FWGLI-EASYNET# show memory
Free memory: 95268744 bytes (71%)
Used memory: 38948984 bytes (29%)
Total memory: 134217728 bytes (100%)
FWGLI-EASYNET# show version
Cisco PIX Security Appliance Software Version 7.0(1)
Device Manager Version 5.0(1)
Compiled on Thu 31-Mar-05 14:37 by builders
System image file is "flash:/pix701.bin"
Config file at boot was "startup-config"
FWGLI-EASYNET up 1 hour 59 mins
Hardware: PIX-515, 128 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 16MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: Ext: Ethernet0 : media index 0: irq 11
1: Ext: Ethernet1 : media index 1: irq 10
2: Ext: Ethernet2 : media index 2: irq 9
3: Ext: Ethernet3 : media index 3: irq 7
Licensed features for this platform:
Maximum Physical Interfaces : 6
Maximum VLANs : 25
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has an Unrestricted (UR) license.
I have no clue... Everything is fine when it reboots from the asdm view ... Memory ok, cpu ok (barely never go further than 10%)
Should i put a fan on the cpu ??
tjgli Wed, 07/04/2007 - 05:47
Update ...
Just discovered the show crashinfo ...
Just in case it could help :
(attached doc)
Googling that 0010dab9 does bring something ... but not very helpfull ,(
MJPGallagher Fri, 08/03/2007 - 01:51
I have a very similar issue. Did you resolve this?
regards,
M
JORGE RODRIGUEZ Fri, 08/03/2007 - 03:50
  • Green, 3000 points or more
version 7.01 is reported to have many bugs casuing crashes based on various conditions.. plan a code upgrade , version 7.2 is a more statble code.
Refere to this furum link for similarities
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=Firewalling&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddf5bad
Bug report based on version code.
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
phillipediab Wed, 10/07/2009 - 11:10
I do have the same issue.It turned out to be a bug in the IOS. The bug is CSCsx64741.
However, 7.01 is not listed withe the version affected
