snmp enable traps slb ft
Jul 4th, 2007
I trying to enable snmp traps on the CSM-S in order to get notification through HP Openview Network Node Manager that a 'fault tolerant' event has taken place. I am running 2.1(5) code.
I found the command reference for the CSMS 2.x code:
http://www.cisco.com/en/US/customer/docs/interfaces_modules/services_modules/csms/2.1.1/command/reference/s.html#wp1057213
There is a reference to the command: snmp enable traps slb ft
This is supposed to send an SNMP trap when the CSM transitions from standby to active after detecting a failure in its fault tolerant peer.
This example shows how to enable fault tolerant traps:
Cat6k-2(config-module-csm)# snmp enable traps slb ft
This command is not available in CSM configuration mode. In fact, there are no snmp commands at all in the CSM config mode.
Do I have to enable something globally on the 6500 first?
