Does Cisco 3750-E switch work in L3/L2
mohammedmahmoud Wed, 07/04/2007 - 06:09
  • Green, 3000 points or more
Initially speaking this is OK, but can you elaborate further for your needs.
HTH,
Mohammed Mahmoud.
royalblues Wed, 07/04/2007 - 06:14
It can be used but you need to have an IP services image to run OSPF
Narayan
i have a fair that this switch are used in this layer of the network that has medium number of host in which most of the time hosts are access the local network. for further information u can see the network topology. IF this is not possible please tell me the equivalent MLS that can work in distribution layer but have an equivalent price with this cisco 3750-E switches
Amit Singh Wed, 07/04/2007 - 06:46
  • Cisco Employee,
This should work for you.There will not be any issues in running 3750-E with this kind of setup. You have to just make sure that you have IP services image on the 3750-E's to support enhanced routing protocols.
-amit singh
Amit Singh Wed, 07/04/2007 - 06:20
  • Cisco Employee,
Yes You can run it with Enhanced image on it.
-amit singh
royalblues Wed, 07/04/2007 - 07:12
Can you post a sh version from your 3750 switch
Narayan
Edison Ortiz Wed, 07/04/2007 - 07:16
  • Hall of Fame,
    Founding Member
You must have a CCO account associated to a contract number in order to download a new image from CISCO. From the legal standpoint, you must purchase the Advanced Services image since you only bought the router with the Standard Image.
The new image adds more features to the router, it doesn't reduce it.
