vlans with 2mft-t1 card and frame relay
Answered Question
Jul 4th, 2007
I am currently trying to extend our metro Ethernet with 1841 routers equipped with a 2mft-t1 card 4esw switch card.
I am trying this using point to point frame relay with separate bridge groups for each Vlan.
Currently the config is working but spanning tree is blocking one of my t1 connections.
Please Help!
Overall Rating: 5 (1 ratings)
alandversitch Wed, 07/04/2007 - 07:00
I believe you are correct I was wondering if any one knew of a workaround. If this was a standard bridge group I believe that I could use circuit groups.
Frame relay does not allow me to apply circuit groups.
alandversitch Wed, 07/04/2007 - 07:30
Thanks for the suggestion.
I have already tried this.
I did manage to get it working.
The speed was very slow. I think it would be better if i had tweaked it.
Spanning tree was still blocking the one link. This seemed very strange to me because ppp multilink works fine when configured with bridge groups.
interface MFR1
no ip address
interface MFR1.1 point-to-point
ip address 10.102.102.2 255.255.255.0
frame-relay interface-dlci 1000
bridge-group 1
interface MFR1.2 point-to-point
ip address 10.103.103.2 255.255.255.0
frame-relay interface-dlci 300
bridge-group 2
interface Serial0/1/0:0
no ip address
ip load-sharing per-packet
encapsulation frame-relay MFR1
no arp frame-relay
interface Serial0/1/1:1
no ip address
no arp frame-relay
router2#show spanning-tree summary
Root bridge for: Bridge group 1, Bridge group 2, VLAN300.
PortFast BPDU Guard is disabled
UplinkFast is disabled
BackboneFast is disabled
Name Blocking Listening Learning Forwarding STP Active
Bridge group 1 2 0 0 1 3
Bridge group 2 0 0 0 2 2
2 Bridge Groups 2 0 0 3 5
VLAN300 0 0 0 1 1
1 VLAN 0 0 0 1 1
Total 2 0 0 4 6
alandversitch Wed, 07/04/2007 - 10:26
I have gone back and retried the mpp frame relay configuration without the ip addresses.
I also made some other changes.
It seems like my spanning tree issue may be ok now but my speed is very slow for the most part but does occasionally burst above 2Mbps.
alandversitch Wed, 07/04/2007 - 11:14
I have turned off the per packet load balancing. This did not seem to make a difference.
I cannot find how to change the fragmentation setting.
Try something like this:
class frag
bridge-group 1
class frag
bridge-group 2
map-class frame-relay frag
frame-relay cir 1536
frame-relay bc 12500
frame-relay be 0
frame-relay mincir 1536
frame-relay fragment 1600
Please note that with these settings both PVCs will get 1536k equally and will be fragmented to 1600 bytes/frame. It will lower serialization delay but obviously you won't have more bandwidth :)
Hope if helps
Krisztian
alandversitch Thu, 07/05/2007 - 05:20
Thanks for your response.
I tried your suggestion but still have very slow speeds.
If I disconnect one of the t1's I get a consistant ~1.4Mbs.
alandversitch Thu, 07/05/2007 - 07:46
Hello
This is the show frame-relay multilink mFR 1 command on both routers. I have tried few versions of ios now. Currnetly I am running 12.4(16)advanced ip the newest one.
I have run a debug and I am getting some errors.
*Jul 5 15:03:12.011: frame_relay_input: F8812000 2B4C5B7, size= 330
*Jul 5 15:03:12.019: frame_relay_input: 48C12000 2B4C4B7, size= 330
*Jul 5 15:03:12.091: MFR1/300: Lost fragment 546 (all links out of sequence)
*Jul 5 15:03:12.491: MFR1/300: Lost fragment 57A (all links out of sequence)
*Jul 5 15:03:12.695: MFR1/300: Lost fragment 594 (all links out of sequence)
The other versions I have tried are
124-6.T7
124-13c
124-11.T2
router1# show frame-relay multilink mfR 1 detailed
Bundle: MFR1, State = up, class = A, fragmentation disabled
BID = first-bundle
No. of bundle links = 2, Peer's bundle-id = first-bundle
Rx buffer size = 24096, Lost frag timeout = 200
Bundle links:
Serial0/1/1:1, HW state = up, link state = Up, LID = Serial0/1/1:1
Cause code = none, Ack timer = 4, Hello timer = 10,
Max retry count = 2, Current count = 0,
Peer LID = Serial0/1/1:1, RTT = 0 ms
Statistics:
Add_link sent = 2, Add_link rcv'd = 1,
Add_link ack sent = 1, Add_link ack rcv'd = 2,
Add_link rej sent = 0, Add_link rej rcv'd = 0,
Remove_link sent = 0, Remove_link rcv'd = 0,
Remove_link_ack sent = 0, Remove_link_ack rcv'd = 0,
Hello sent = 951, Hello rcv'd = 949,
Hello_ack sent = 949, Hello_ack rcv'd = 942,
outgoing pak dropped = 0, incoming pak dropped = 0
Serial0/1/0:0, HW state = up, link state = Up, LID = Serial0/1/0:0
Peer LID = Serial0/1/0:0, RTT = 0 ms
Statistics:
Hello sent = 946, Hello rcv'd = 1052,
Hello_ack sent = 1052, Hello_ack rcv'd = 946,
router2#show frame-relay multilink mFR 1 detailed
BID = first-bundle
Bundle links:
Statistics:
Add_link sent = 2, Add_link rcv'd = 2,
Add_link ack sent = 2, Add_link ack rcv'd = 1,
Hello sent = 892, Hello rcv'd = 893,
Hello_ack sent = 893, Hello_ack rcv'd = 894,
Cause code = none, Ack timer = 4, Hello timer = 9,
Max retry count = 3, Current count = 0,
Statistics:
Hello sent = 991, Hello rcv'd = 891,
Hello_ack sent = 891, Hello_ack rcv'd = 991,
alandversitch Thu, 07/05/2007 - 08:57
This is actually a back to back link to extend our metro ethernet service.
Currently the 2 routers are on my desk and have 2 t1 crossovers connected between them.
There should be no difference in delay.
alandversitch Thu, 07/05/2007 - 10:30
Turns out I didn't have the controller clock set properly. The speed is now fine.
I can now go on with my testing.
Thanks for all of your help it was great.
