Admin access right in 3005 VPN Concentrator
Jul 4th, 2007
Hi All,
I have a VPN concentrator 3005 but unknowingly I created a user and gave it admin right. Now i do not have admin access on both the user and the old admin account. I have read about password recovery but I am confused on the solution note that says if I am running a code 2.5 or earlier, i should contact TAC. Question " is my concentrator running 2.5 or 4.7 based on the information below.
Bootcode Rev: Cisco Systems, Inc./VPN 3000 Concentrator Series Version 2.5.Rel Jun 21 2000 18:57:52
Software Rev: Cisco Systems, Inc./VPN 3000 Concentrator Version 4.7.Rel Mar 10 2005 14:58:16
pc
rochopra Wed, 07/04/2007 - 15:49
  • Cisco Employee,
The line in password recovery document refers to Bootcode version.
Rohit
peteruwa Thu, 07/05/2007 - 00:08
Thanks Rohit. Does that mean I have to contact TAC for assistance or will the password recovery procedure still work for me even though the bootcode is release 2.5? I will need a password recovery procedure for releasae 2.5
Pc
rochopra Thu, 07/05/2007 - 05:03
  • Cisco Employee,
I will recomend you to ocntact TAC as you are using fairly old version of bootcode
Rohit
peteruwa Mon, 07/09/2007 - 07:59
Pls does anyone know the procedure for password recovery of VPN concentrator with release 2.5 or below. I have contacted TAc but not getting the adequate help at the moment.
PC
