Setting up accounts with 1812 router
Jul 4th, 2007
hi im trying to setup user accounts into the router to restrict access to the internet, i want it that users require to enter a passcode for internet access when they try to access the net
sherlockpayne Wed, 07/04/2007 - 14:15
ok im reading the doc u sent, good stuff
is it possible to set up the box with users and accounts? can i set this up with out any servers etc etc? im using it as part of a sort of wireless hotspot in a bar enviroment.
mohammedmahmoud Wed, 07/04/2007 - 22:43
Unfortunately AFAIK you must use TACACS+ or RADIUS for authentication and authorization in the case of auth-proxy, any way you can have an open source RADIUS to do this for you, like the famous FreeRADIUS:
http://www.freeradius.org/
HTH,
Mohammed Mahmoud.
Jon Marshall Wed, 07/04/2007 - 23:05
I think Mohammed is spot on with this. I did think you would be able to use local accounts on the router but after some further reading it looks like you have to use a Radius/Tacacs server.
Windows has a AAA server but i don't know whether it is compatible, otherwise as Mohammed says there are free versions out there.
Jon
Jagdeep Gambhir Thu, 07/05/2007 - 05:12
Windows Radius is compatible. I guess you should go for Radius implementation. By this users would be prompted for user name /pwd and then only it will allow user to access http.
All your user accounts will be on Radius.
~JG
sherlockpayne Tue, 07/10/2007 - 09:29
well im using freeradius for windows and it seems to be functioning so far so good
my implementation is for free http access in a sports bar, currently im trying to upload a htm file to the router in order to place the terms and conditions b4 login but it is saying the file has to be under 8000 bytes, is there a way to get around this or is there a way i can redirect users to an html page or site where i can place the terms and conditions along with the bar's logo?
thanks
sherlockpayne Thu, 07/12/2007 - 05:52
any info on getting a terms and conditions page to pop up b4 during or after login? im using the log in banner but after formatting the txt file it appears condensed when i envoke a login page.
