WS-X6148A-GE-TX is unrecognized in Sup2MSFC2 (Native)
Jul 4th, 2007
I?m trying to get a WS-X6148A-GE-TX going with a 6509 that is using a Sup2MSFC2 < WS-X6K-SUP2-2GE> in Native mode.
The sup2 has 32MB Flash and 128MB RAM.
I?ve used the IOS upgrade adviser to see what the minimum IOS version is that will fit on the Sup2 and that will recognize the WS-X6148A-GE-TX.
The version is : 12.1(27b)E2.
But it fails to recognize the card,
00:00:57: %OIR-SP-3-UNKNOWN: Unknown card in slot 7, card is being disabled
Overall Rating: 4 (1 ratings)
Edison Ortiz Wed, 07/04/2007 - 14:01
You need to upgrade the memory to 256MB and the flash to 64MB in order to download the 12.2 release since that's the version that supports that card:
Unsupported Hardware
The following hardware is not supported:
In Release 12.2(27b)E2 and later releases, Supervisor Engine 1.
Supervisor Engine 720
Supervisor Engine 32
Distributed Forwarding Card 3 (DFC3A, DFC3B, DFC3BXL)
WS-X6748-GE-TX 48-port 10/100/1000 RJ-45 Ethernet switching module
WS-X6748-SFP 48-port Gigabit SFP Ethernet switching module
WS-X6724-SFP 24-port Gigabit SFP Ethernet switching module
WS-X6704-10GE 4-port 10-Gigabit XENPAK Ethernet switching module
WS-X6148A-GE-TX, WS-X6148A-GE-45AF 48-port 10/100/1000 Mbps RJ-45 Ethernet switching module
WS-X6148A-RJ-45, WS-X6148A-45AF 48-port 10/100TX RJ-45 Ethernet switching module
WS-X6148-FE-SFP 48-port 100BASE-FX SFP Ethernet switching module
WS-X6148X2-RJ-45, WS-X6148X2-45AF 96-port 10/100TX RJ-45 RJ-45 Ethernet switching module
WS-X6196-RJ-21, WS-X6196-21AF 96-port 10/100TX RJ-21 Ethernet switching module
WS-X6582-2PA Enhanced FlexWAN Module
These FlexWAN port adapters:
PA-A6-OC3MM 1-port ATM OC-3c/STM-1 multimode port adapter, enhanced
PA-A6-OC3SMI 1-port ATM OC-3c/STM-1 single-mode (IR) port adapter, enhanced
PA-A6-OC3SML 1-port ATM OC-3c/STM-1 single-mode (LR) port adapter, enhanced
PA-A6-T3 1-port ATM DS3 port adapter, enhanced
PA-A6-E3 1-port ATM E3 port adapter, enhanced
WS-SVC-IPSEC1 IPsec Virtual Private Network (VPN) acceleration service module
WS-SVC-PSD-1 Persistent Storage Device service module
WS-SVC-MWAM-1 Multi-Processor WAN Application Module
WS-X6624-FXS, WS-X6608-T1, and WS-X6608-E1 voice modules
WS-X6101-OC12-MMF and WS-X6101-OC12-SMF ATM LANE modules
WS-X6302-MSM Multilayer Switch Module
These modules remain powered down if detected and do not affect system behavior.
