NAT exempt
Jul 4th, 2007
Can somebody explain the difference between the commands:
static (inside,dms) 10.1.0.0 10.1.0.0 netmask 255.255.0.0
and
nat (inside) 0 access-list NoNat
access-list NoNat permit ip 10.1.0.0 255.255.0.0 any
After Updating from 7.x to 8.x the second command doesn't work anymore. Because there was no translation group.
Kind regards,
Martien
srue Thu, 07/05/2007 - 05:49
  • Blue, 1500 points or more
access-list NoNat will cause ALL traffic from 10.1.0.0/16 to not be NAT'ed, no matter where its going.
your static NAT entry will only cause 10.1.0.0/16 to not get NAT'ed if it's going to the dmz interface, otherwise it is subject to other nat (inside) rules.
