2950 - Loopback error
Jul 4th, 2007
I get a LOOPBACK error message on my 2950 switch which disables the port. What should I check for ? I have no idea where to start. Whats causing this?
Edison Ortiz Wed, 07/04/2007 - 18:07
Can you please post the exact error and also the output from typing
show interfaces status err-disabled
royalblues Wed, 07/04/2007 - 19:43
There was a bug filed but it was junked, because it is mostly caused by a STP loop or bad cabling. The following bug more details on this
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCea46385
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12220se/3750smg/msg_desc.htm#wp98430
You might also want to consider err-disable recovery. You can enable it using
2950-A#conf t
Enter configuration commands, one per line. End with CNTL/Z.
2950-A(config)#errdisable recovery cause loopback
HTH, rate if it does
Narayan
