urgent: Error when access outside FTP thru ASA
I have getting this error in the log when trying to access FTP outside our LAN. Could anyone tell me what's wrong?
6|Jul 04 2007 18:53:33|302013: Built outbound TCP connection 1601826 for outside:207.46.236.102/21 (207.46.236.102/21) to inside:192.168.1.199/14561 (38.103.153.130/23862)
attached is my current config
JBDanford2002 Wed, 07/04/2007 - 15:38
Thats not an error. Its just a message saying a connection was established. Is there a problem with FTP? Was it working before? When did it stop working?
srue Thu, 07/05/2007 - 05:47
  • Blue, 1500 points or more
why is the following command configured:
no ftp mode passive
try doing:
ftp mode passive
I had tried that and made no different. However here's the latest.
class-map inspection-default
match default-inspection-traffic
policy-map global-policy
class inspection-default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect http
inspect pptp
inspect snmp
inspect ctiqbe
inspect ils
inspect mgcp
inspect icmp error
inspect icmp
class class-default
csc fail-close
inspect pptp
service-policy global-policy global
The above section was giving alot of problems, http access was messed up such as trouble accessing gmail.com, the ASA would reboot by itself. http access to configure ASA was messed up as well. I had to take that out for the ASA to work ok again.
Any idea why?
Then I added:
access-list inside permit tcp any any eq ftp
access-list inside permit tcp any any eq ftp-data
access-group inside in interface inside
now ftp works for most workstations on our LAN except my pc which worked perfectly before we installed the ASA.
Any idea?
Tshi M Thu, 07/05/2007 - 06:28
  • Silver, 250 points or more
try to remove your access-list inside. Traffic from the higher security are always allow. See if that helps.
acomiskey Thu, 07/05/2007 - 06:31
  • Green, 3000 points or more
If you look at his initial config he has the inside acl written perfectly. He is trying to limit outbound pptp, so he allowed pptp to 1 host, denied pptp to all others, then had a permit ip any any. This is why adding the ftp access in the acl makes no sense to me.
