ASA 5520 Firewall
hussainkhalid
I need to remove one NAT which is there, through GUI it wont allow my saying some security rule warning. i also tried to disable security rule and tried but still couldnt do it.
now i was thinking to remove from command line.
the NAT is shown below
static (Inside,Outside) XXX.XXX.XXX.XXX XXX.XXX.XXX.XXX netmask 255.255.255.255
The ip address for Inside, Outside is the same so i was trying to remove it. could any one tell me how can i remove this line from command line??
waiting...
6 Replies 6
zulqurnain
Level 3
Level 3
hello,
on the prompt write
(config)# no static (Inside,Outside) XXX.XXX.XXX.XXX XXX.XXX.XXX.XXX netmask 255.255.255.255
hth, please rate it
no static (Inside,Outside) 62.215.215.215 62.215.215.215 netmask 255.255.255.255
^ clear global 62.215.215.215 Local 62.215.215.215
ERROR: % Invalid input detected at '^' marker.
I GET THIS ERROR MESSAGE! PLEASE HELP ON THIS!
clear xlate global 62.215.215.215
tried this as well, but
didnt work, doesnt give any error... but when i say
sh xlate
the entry is still there!
do i need to remove NAT before that?
any help on this please?
hello,
do the above as suggested and reload your firewall.
hth, please rate it
doesnt work!! is there any thing else linked with this which i need to delete before i run this command?? i tried to delete xlate before i delete the nat! doesnt work!
