07-05-2007 01:09 AM - edited 03-14-2019 10:24 PM
I want to integrate a PBX Philips Sopho with a Cisco CME setup using an E1 (QSIG) connection to the PBX.
I'm getting this error from debug:
Jul 5 09:08:50.808: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x5F00
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA3
Preferred, Channel 2
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '2456'
Plan:ISDN, Type:Unknown
Jul 5 09:08:50.808: ISDN Se0/0/0:15 Q931d: L3IF_rx_L2_pak: received data
Jul 5 09:08:50.808: 08025F000504039090A31801A31E0281
Jul 5 09:08:50.808: 836C06018032343536
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: source 0x020A, event 0x0005, call id 0x int id 0x0
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: event 0x5 cr_len 2 cr 57088
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_state_change: callref 0x0000 old UNKNOWN_STATE, new NULL_STATE
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: call_id 0x0 cr 0xDF00 state 0 event 0x5 ces 1
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_ProcessEvent: callref = 0xDF00 SETUP:U0_Setup(nlcb)
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_state_change: callref 0x0000 old NULL_STATE, new UNKNOWN_STATE
Jul 5 09:08:50.812: ISDN Se0/0/0:15 **ERROR**: CCPMSG_InCall: ChannelID IE invalid 100(0x64) rejecting call
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: source 0x0400, event 0x0087, call id 0x int id 0x2F
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: event 0x87 cr_len 2 cr 57088
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: call_id 0x2F cr 0xDF00 state 0 event 0x87 ces 1
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_ProcessEvent: callref = 0xDF00 CC_BROADCAST_RESP:U0_BroadcastResp(nlcb)
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_state_change: callref 0xDF00 old NULL_STATE, new CALL_PRESENT
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: source 0x0400, event 0x0082, call id 0x int id 0x2F
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: event 0x82 cr_len 2 cr 57088
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: call_id 0x2F cr 0xDF00 state 6 event 0x82 ces 1
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_ProcessEvent: callref = 0xDF00 CC_SETUP_REJ_REQ:U6_SetupRejReq(nlcb)
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_TxSarMsg: InfoLen = 10 octets
Jul 5 09:08:50.812: 0802DF005A080380E418
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: srl_send_l3_pak:
source_id = Q.931 0x0300, dest_id = Q.921 0x0000, prim = DL_DATA_REQ 0x0240
priv_len = 4 int_id = 0x47C1C7C4 datasize = 26
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: data =
Jul 5 09:08:50.812: 47C1C7C4000003000240040000010806
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_state_change: callref 0xDF00 old CALL_PRESENT, new NULL_STATE
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xDF00
Cause i = 0x80E418 - Invalid information element contents
Any ideas?
Cheers,
Hefin
07-05-2007 01:23 AM
Which IOS are you using ? Config ?
The thing is that called number is missing in setup, what number where you calling ?
07-05-2007 01:40 AM
07-05-2007 01:57 AM
Ok, can you trying configuring:
voice service voip
qsig decode
and take another 931 trace.
Something a bit strange is that you have the router in user-side, not network. To what the PBX was connected before, if anything? Do you have access to the PBX configuration ?
07-05-2007 07:53 AM
I'll try an get the configuration changed over so that the router is the master, and the PBX as the slave.
Let you know how we get along
Cheers,
Hefin
07-05-2007 07:59 AM
Ok, but from the config you sent, it appears this is already the case.
07-11-2007 04:42 AM
Ok, re-configured the isdn switch-type to be primary-net5 and everything now works.
Anybody know if there are any issues with runing a CCME system with a net5 connection?
07-11-2007 04:58 AM
There are no issues, net5 is the most used switchtype worldwide.
Please remember to rate useful posts using the scrollbox below!
