Header-map not working in CSM-S
Answered Question
Jul 5th, 2007
We are trying to configure an application using both a url and header map in the policy:
natpool DOC-PROD-NAT 10.1.1.1 10.1.1.1 netmask 255.255.255.128
probe DOC-GLIB-PROD http
request method get url /globelib/webcomponent/testbed/CLASSPATHTool.jsp
expect status 401
interval 15
retries 2
failed 30
open 2
map DOC-GLIB-PROD url
match protocol http url /globelib*
map DOCUMENTUM-PROD header
match protocol http header Host header-value ecm.ctr.globeint.ddc
serverfarm DOC-GLIB-PROD
nat server
nat client DOC-PROD-NAT
real name DDINTA34 7000
inservice
real name DDINTA37 7000
inservice
probe DOC-GLIB-PROD
sticky 66 cookie DOC-GLIB-PROD insert
policy DOC-GLIB-PROD
url-map DOC-GLIB-PROD
header-map DOCUMENTUM-PROD
sticky-group 66
vserver DOC-CSFSAP-PROD
virtual 10.1.1.1 tcp www
no persistent rebalance
slb-policy DOC-GLIB-PROD
inservice
The problem we have is that it does not work with the header map. As soon as I remove the header map from the policy it starts to work. It does not also work without the header map alone without the url map under the policy. As per Cisco documentation I don't see any issue with this config.
We have disabled persistent rebalancing due to the fact that CSM does not support http pipelining and this application uses it.
Any help will be appreciated.
Murtaza
Correct Answer by Gilles Dufour about 9 years 7 months ago
ok, I was able to detect the issue and reproduce it in my lab.
Your client sends the host value ecm.ctr.globeint.ddc:80 and it does not match your header-map.
If you change your header-map to look like this
match protocol http header Host header-value ecm.ctr.globeint.ddc*
then it works fine.
Gilles.
Overall Rating: 5 (1 ratings)
Gilles Dufour Thu, 07/05/2007 - 03:53
could you please describe 'does not work'.
Is it the first request that does not hit the appropriate policy ? or subsequent request ?
What happens with your request when it fails ? just hang or reset ?
Could you capture a sniffer trace showing the problem.
What version do you run ?
Gilles.
hussainmo Thu, 07/05/2007 - 06:48
This application is a document respository. With this config we are able to connect to the application but when we try to open a document this action fails and we get a ucf error. However when the header map is removed we can open the same document successfully.
Based on this I would say that its the subsequent request that fails.
Its resets almost immediately.
I have 2 captures. One with (called header map which does not work) and the other without the header map (called url map which does work). Currently I am trying to attach these with IP addresses suppressed but so far I am out of luck. As soon as I figure it out I will attach them.
The software version is 2.1.4
Murtaza
hussainmo Fri, 07/06/2007 - 01:22
I hope I understand your question.
When I took the capture url map (the working situation) I had the following config in place:
sticky-group 66
When I took the header map capture (the non working solution) I had the following config on the CSM:
sticky-group 66
Let me know if I have misunderstood your question.
Murtaza
Correct Answer
Gilles Dufour Fri, 07/06/2007 - 01:28
then it works fine.
Gilles.
