Debug CUE programs
Answered Question
Jul 5th, 2007
  • Silver, 250 points or more
I have made many programs for IPCC express and one of the features is the Debug Reactive script.
Basically it lets you step by step (F10) go through the program. This is a very nice debug tool.
Now I have to make a program on Unity Express using the CUE editor. The editor looks in many ways the same as the CRA editor found on IPCC express, except the debug reactive script.
Is there a way to "debug" CUE applications?
Bye,
Correct Answer by Rob Huffman about 9 years 9 months ago
Hi Jan,
The Debug feature is available with CUE Scripts as well. Have a look at the following;
Debugging features, available through the Debug menu, enable you to debug your script using the CUE Editor. You can select the script to debug, use breakpoints, proceed step by step through the script, and see the values of variables change as the script runs.
Debugging Features
You can access debugging features through the debug menu or the toolbar.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_administration_guide_chapter09186a008067a1c3.html#wp1078755
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Thu, 07/05/2007 - 04:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jan,
Debugging Features
From this good doc;
Hope this helps!
Rob
j.huizinga Thu, 07/05/2007 - 06:22
Ah yes, I was using CUE version 2.1
Anyway upgraded to 2.3 and now have the debug option.
Thank you very much Rob for your quick response,
Jan
Rob Huffman Thu, 07/05/2007 - 08:43
  • Hall of Fame,
    Founding Member
Hi Jan,
You are most welcome :)
Take care,
Rob
