Expression - Internal Extension
Answered Question
Hi !!
I want to identify if a caller is calling to IPCC from an internal extension.. (4 digits 4000-4999 or 8000-8999)
Im trying to use the IF STEP, but im not sure how to write this expression:
if ( varNumberInt >= 4000 | varNumberInt <=4999)
varExtension == 1;
else
if ( varNumberInt >= 8000 | varNumberInt <=8999)
varExtension == 1;
ps. all variables are Integer
Thanks !
[email protected]
Andrei.
Correct Answer by lpezj about 9 years 11 months ago
Andrei,
You can use this expresion in the IF node:
(varNumberInt >= 4000 && varNumberInt <=4999) || ( varNumberInt >= 8000 && varNumberInt <=8999)
If this expresion is true you must add to the IF true branch a SET statment that gives to varEstension the value of 1.
The ANI value is a string variable that you must convert to integer.
Hope this helps,
Juan Luis
Overall Rating: 5 (1 ratings)
Correct Answer
lpezj Thu, 07/05/2007 - 04:31
  • Gold, 750 points or more
Andrei,
Hope this helps,
Juan Luis
