IP Nat Inside Source Static
mikntwd49508
I would like to add the following configuration to FastEthernet0/1.200.
"IP Nat Inside Source Static 10.1.0.11 216.x.x.x" (x=hidden numerical value for purpose of this forum/internet).
HOWEVER,
current assignment is configured as:
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list NAT interface FastEthernet0/1.200 overload
ip nat inside source static 10.1.0.10 216.109.x.x (x=hidden values for purpose of this forum/internet).
*** When I attempted to add the new value, a error message appeared stating another entry for this IP address already exists; 216.109.x.x.
Can I configure same interface with two private ip addresses to allow dns & mail?
Can you try using the dynamic rules as below?
ip nat pool pool1 216.109.x.10 216.109.x.10 prefi 30
ip nat inside source list 1 pool pool1
access-list contain permit 0.10 and 0.11
I think this one solves your problem.
HTH,
Radhika
8 Replies 8
Jon Marshall
Can you add the keyword "extendable" to each of your "ip nat source static ..." commands. eg
ip nat inside source static 10.1.0.10 216.109.x.x extendable
etc.
This allows the router to use port number for mappings as well which should allow it to resolves 2 private addresses to the same public.
Jon
Ok, i just entered:
ip nat inside source static 10.1.0.10 216.109.x.x extendable. After entering it, it appears to have accepted it.
Then I entered:
ip nat inside source static 10.1.0.11 216.109.x.x
I got the following error:
DPI-CME-2811(config)#$de source static 10.1.0.11 216.109.x.x extendable
% similar static entry (10.1.0.10 -> 216.109.202.34) already exists
Sorry, was just editing my previous reply
ip nat inside source static tcp 10.1.0.10 25 216.109.x.x 25 extendable
ip nat inside source static udp 10.1.0.11 53 216.109.x.x 53 extendable
This obviously covers mail and DNS but i don't know which port goes with which server.
Jon
I appreciate the prompt replies and information.
I am a little confused.
In your recent reply, you indicate two private IP addresses; each one having a separate port number to reflect that service.
wouldn't I create two entries as follows because the *.11 is new mail server:
ip nat inside source static tcp 10.1.0.11 25 216.109.x.x 25 extendable
I'm a little confused now. I though that was what you wanted ie. to map 2 private IP addresses to the same public IP.
Jon
YES. :-)
Currently,
ip nat inside source static 10.1.0.10 216.109.x.x.
I want to add a new mail server, 10.1.0.11 so it can be accessed via internet.
I was trying to add:
ip nat inside source static 10.1.0.11 216.109.x.x. but received error.
Okay
Can you provide details of excatly what you want to re port numbers and private IP addresses.
I'm assuming you are using the same public IP address ?
Jon
HTH,
Radhika
