Empty Logonpage with WebVPN / ASA 8.0.2
Jul 5th, 2007
I bought a new ASA 5505 and installed Version 8.0.2. I configured WebVPN and everything about it without any problems and most things worked fine. After making some changes to the custompage the logonpage is empty and I can't login.
I deleted the startup-config and all files on flash, did a new setup and the config of the custompage shows me the old values. Also the bookmarks I configured are there. Where is the config saved at? Flash was empty (only IOS on there).
THX
MB
beth-martin Wed, 07/11/2007 - 05:30
  • Bronze, 100 points or more
The caonfiguration were saved in nvram
MaseBarnes Tue, 07/17/2007 - 04:23
Do you know how to edit/delete the corresponding files in there?
