VLAN Access Maps and HSRP, OSPF
Jul 5th, 2007
Hi all,
I have created a VLAN that will house our printers.
The VLAN is served by two c3750 switches running HSRP.
I want to filter traffic on the VLAN interface to allow only a specific network and host to have full access to the VLAN, but allow everyone else to ping.
Ive created an extended IP access list as follows:
ip access-list extended printeraccess
permit ip any
permit ip host any
permit icmp any any
I then apply this with an access map as follows:
vlan access-map printer 10
match ip address printeraccess
action forward
vlan filter printer vlan-list 106
This all works fine, except HSRP is now blocked, and OSPF also.
I add the following line to the access-list to allow HSRP:
permit udp any any eq 1985
After this the HSRP cluster comes back to life, but no other communication is allowed over the VLAN - not even the ICMP.
As soon as I remove this statement again, ICMP and IP access starts working but the HSRP cluster falls over.
I will eventually need to add permit ospf any any. But I wanted to get this sorted first.
Any ideas?
Amit Singh Thu, 07/05/2007 - 10:32
Check, what "show access-list printeraccess " shows you. I would recommend to delete the entire ACL and then rewrite it and then apply to the Vlan access Map.
permit ospf any any
permit ip any
permit ip host any
permit icmp any any
HTH,Please rate if it does.
-amit singh
misd.network.support Mon, 07/09/2007 - 06:06
Ive tried recreating the Access List several times. The syntax is definitely correct.
As soon as I remove the permit udp any any eq 1985 statement from the Access list everything springs into life. As soon as I add it again, everything is dropped.
Ive tried on swapping the active roles on the HSRP and applying the access list on the other switch too. Exactly the same result.
