configuration for g/w to g/w VPN ??
bansal_rajeshkr
Hi all,
I am configuring g/w to g/w VPN. For this VPN server is demanding remote peer address and remote gateway address. but i don't know what should be these.
my side configuration is this
I have a broadband connection with public IP 59.x.x.133 which is given to my router. on roouter there is one more IP for local LAN that is 192.168.57.1 .
now please tell me which one is gateway address for g/w to g/w VPN and which one is remote peer address.
Rajesh Kumar
Rajesh,
What you are trying to do is called site-to-site VPN. You need to peer to the public IP of the router/gateway on the far end. The following link has configuration examples for many VPN scenarios. Just select the right option for you.
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html
Let us know if this helps.
Sundar
