SIP Register problem
anthonyfear
Hi All
receiving this when trying to register sip:
Jul 5 15:31:33.031: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:217.10.79.23:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.4.253:5060;branch=z9hG4bK5211AC
To: <sip:7828151@217.10.79.23>
Date: Thu, 05 Jul 2007 15:31:33 GMT
Call-ID: 232B9E6D-2A3F11DC-8012D821-FEE92517
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1183649493
CSeq: 11 REGISTER
Contact: <sip:7828151@192.168.4.253:5060>
Expires: 3600
Content-Length: 0
Jul 5 15:31:33.099: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden (client configuration error)
Via: SIP/2.0/UDP 192.168.4.253:5060;rport=50062;branch=z9hG4bK5211AC
To: <sip:7828151@217.10.79.23>;tag=8367f0f887e3954243ec30fa0f5db288.4967
CSeq: 11 REGISTER
Content-Length: 0
Any ideas?
I'm runing 12.4(15)T with cme 4.0.1
6 Replies 6
paolo bevilacqua
What device are you using for NAT? If it is not translating the embeeded address correctly, the the remote SIP-UA may be seeing you private IP address and get upset about it.
I'm using the same 837 router with NAT that I always have.
It's worked previously and there hasn't been any change on the 837.
Any ideas?
Did it happened after upgrade to 12.4(15)T ?
If so, would you be able to go back and compare traces ?
Looks like it was coincidence that I happen to upgrade today and the sip registration stops working!!!
I went back to 12.4(11) - no registration
then went back to 12.4(9) - still no registration.
So I tried different provider - registered!
Upgraded to 12.4(11) - registered!
Upgraded to 12.4(15) - still registers!
Must be down to my sip provider! Arrgghhhhhh!
Thanks anyway
Hi There
Got a reply from the sip provider today telling me they have changed their expires timeout from 3600 to 600.
I've changed sip-ua registrar statement to :
registrar ipv4:x.x.x.x expires 600
but it's still not working - do i need to change anything else?
debug ccsip all
attached
