isteam Fri, 07/06/2007 - 11:53
I have had the most luck with http://www.ethereal.com/ for capturing and troubleshooting packets.
Steps are as follows:
1. Install Ethereal on a laptop/PC
2. Connect to switch that spambox is on.
3. Configure a SPAN session to mirror packets to the port your laptop is plugged into.
4. Start capturing packets.
You can filter the capture to display only HTTP/SMTP if you choose.
If you are just looking for traffic information, www.ntop.org makes a pretty handy free analyzer.
a.shaukat Mon, 07/09/2007 - 02:57
u can use a netflow analyser to monitor traffic ( if this traffic passes through the router)
AdventNet NetFlow Analyser
