07-05-2007 09:09 AM - edited 03-05-2019 05:09 PM
I want to change values of DNS & WINS to new IP 10.1.0.6 but I do not know how to do so.
Current value of running config is:
rypto isakmp client configuration group XYZVpnGroup
key backVPNk3y
dns 10.1.0.12
wins 10.1.0.12
domain xyz.com
pool VPNPool
acl Split
Solved! Go to Solution.
07-05-2007 09:23 AM
As both Narayan and myself have in the configs
dns 10.1.0.6
wins 10.1.0.6
Jon
07-05-2007 09:16 AM
Remove the crypto map which is assigned to the interface.
no crypto map
Then use the no form of the comand under the clinet group configuration. I think it should do the trick
crypto isakmp client configuration group XYZVpnGroup
no dns 10.1.0.12
no wins 10.1.0.12
dns x.x.x.x
wins y.y.y.y
Narayan
07-05-2007 09:18 AM
From conf t mode on your router
2811_rtr(conf t)# crypto isakmp client configuration group XYZVpnGroup
and then type
no dns 10.1.0.12
no wins 10.1.0.12
dns 10.1.0.6
wins 10.1.0.6
Jon
07-05-2007 09:21 AM
Ok.
How do I add the new values of DNS 10.1.0.6 and WINS 10.1.0.6?
07-05-2007 09:23 AM
As said earlier, remove the old dns entry using the no form of the command and add a new entry using
dns
wins
Narayan
07-05-2007 09:24 AM
Sorry Narayan, our postings keep getting crossed :-)
07-05-2007 09:30 AM
Seems only fair that we both get rating for this
Jon
07-05-2007 09:23 AM
dns 10.1.0.6
wins 10.1.0.6
Jon
