WLC4402 and ACS receives double authentication request with MS client
Jul 5th, 2007
I have a 4402 wlc, ACS 3.3 and we use Microsoft client with WPA-TKIP/MSChapv2.
We hardly connect to the WLAN, but after 10 minutes we are disconnected.
We are migrating from LEAP to PEAP, so we create two profiles in the WLC.
LEAP connects good, but PEAP fails.
In the ACS log I can see a double authentication request.
Any idea?
rochopra Thu, 07/05/2007 - 14:47
Try increasing timeout on WLC for radius.
Try checking/ unchecking Fast Reconnect on clients and ACS server.
Rohit Chopra
Dominic Stalder Mon, 02/04/2008 - 05:02
I try to use two SSID's with different EAP-Authentication on the ACS. How did you configure the two Profiles exactly?
Thanks in advance
moises.rodriguez Mon, 02/04/2008 - 07:02
Create two profiles with differente name and same SSID, then you can assign one of them with 802.1x and dynamic wEP, and the second with 802.1x with WPA. The firmware versión should be 4.1.217 or higher
Dominic Stalder Mon, 02/04/2008 - 08:42
but that doesen't solve the problem on the ACS right?! On the ACS I have to configure the device with the ip address and the EAP type (ex. "Cisco Aironet" for LEAP or "Cisco IOS/PIX" for PEAP), and how do that?
Thanks for your feedback
Trending Topics - Security & Network
