VIC2-4FXO port problem, Hardware ???
Hi everyone, i am new to this site...
I just installed 2x VIC2-4FXO on a 2801 router, on the 1st card, the last port (0/0/3) have the IN USE amber led on since I installed the card, but much brighter than normal... and the port isn't working at all. Any suggestion ?
Software version, 12.4(11)XJ3
Overall Rating: 4.5 (3 ratings)
Paolo Bevilacqua Thu, 07/05/2007 - 17:40
Perhaps it got stuck. Try shut no/shut the voice-port, but if it stays like that you have to reload the router. If it stays like that and no line connected, is defective.
i tried shutdown and no shutdown couples of time before, didn't help, but this problem appeared when I installed this card few weeks ago (brand new router with brand new card). I also reloaded the router couple of time since then... I was wondering if there was a way to hard reset the card ... I guess it is defective ! thanks for the reply !
I am also having an issue with thoses external FXO port, poor line quality, bad audio and i am also having a delay between the time i dial an external number to the PSTN and the connection, about 5 sec...
