I need a tunnel with NAT
Pix 515 6.3(3) has a pix to pix VPN, then, it has some vpn clients, all they are working fine, however, I need an aditional VPN to a VPN concentrator, and I have a problem, for security policies the partner which I need to connect does not permit my internal ip address, then I need to make NAT in order to get access to its network.
my internal is address 10.0.0.0, but need to make NAT to 172.16.1.0, But i do not know how to establish that nat and the access-lists.
can somebody help me ??
Martin C
eric_hanke Thu, 07/05/2007 - 11:38
I am having a similar issue. I have a Cisco PIX 501 that already has several site-to-site connections established.
I need to establish an additional VPN to a device that already has a connecton that uses the IP addresses on my LAN interface. Is there a way to NAT my LAN so I can establish the VPN without putting another piece of hardware in place?
Thanks.
Jon Marshall Thu, 07/05/2007 - 11:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Eric
The solution for Martin should also work for you.
Jon
Jon Marshall Thu, 07/05/2007 - 11:56
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Martin
Let assume the remote partner network is 192.168.5.0 255.255.255.0
Also lets assume you only want to NAT your 10.0.0.0 addresses to 172.16.1.0 when you access your partner network.
access-list pnat permit ip 10.0.0.0 255.255.255.0 192.168.5.0 255.255.255.0
nat (inside) 2 access-list pnat
global (outside) 2 172.16.1.0 255.255.255.0
The above makes sure your 10.0.0.0 addresses are only natted to 172.16.1.0 when going to the partner network.
Now you setup your pix to VPN concentrator VPN in the same way as you have setup your pix to pix VPN. The major difference is on the crypto map access-lsit on your pix. You must refer to the Natted addresses ie.
access-list vpntraffic permit ip 172.16.1.0 255.255.255.0 192.168.5.0 255.255.255.0
Jon
Jon Marshall Fri, 07/06/2007 - 22:40
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
No problem, glad to have helped.
Jon
