7609 supengine32 active/standby issue
Jul 5th, 2007
Dear all,
I have 7609 router with two sup engines. The LAN uplink is connected to ports 5/9 and 6/9. when the active port 5/9 fails (cable unplugged), the backup port 6/9 didnt take over. Is this normal, or I need to do some configuration.
a-vazquez Thu, 07/12/2007 - 09:00
  • Silver, 250 points or more
I think slot 2 can contain an additional redundant supervisor engine, which can act as a backup if the first supervisor engine fails. If a redundant supervisor engine is not required, slot 2 is available for an OSM or other supported Catalyst 6000 family modules.
http://www.cisco.com/en/US/products/hw/routers/ps368/products_installation_guide_chapter09186a008007e042.html#wp1048235
