07-05-2007 01:33 PM - edited 03-03-2019 05:44 PM
I Bought a NM-8A/S, only that isn't operating. Do you know as i can raise connection to 256 Kbps?
Solved! Go to Solution.
07-05-2007 02:20 PM
Sorry, it supports only up to 128 kbps in sync mode.
07-06-2007 12:05 AM
There is none of 8 ports. NM-4T has four ports.
07-06-2007 01:26 AM
you may check out if HWIC-8A/S-232 is helpfull? But max speed is only 256kbps
Cheers!
07-05-2007 02:20 PM
07-05-2007 07:03 PM
Ok, thanks
Do you know that other Network Module of 8 serial can i buy? for connect it a link of 256 Kbps? I have five link of diferents speeds
07-06-2007 12:05 AM
07-06-2007 01:26 AM
Cheers!
