Removal of IP Access-List Extended Policy Entry
Jul 5th, 2007
Hi.
I need to know what commands (how) to delete a duplicated entry in running configuration of Cisco 2811 Router.
Current config shows:
ip access-list extended Policy-NAT
permit ip host 10.1.1.11 192.168.2.0 0.0.0.255
ip access-list extended Policy-Nat
permit ip host 10.1.0.11 192.0.0.0 0.0.255.255.255
*** Notice- the two naming conventions are similar but one has capital letters and has wrong ip of 10.1.1.11.
The second entry shows correct IP 10.1.0.11.
*** All I want is correct value for the following in running-config:
permit ip host 10.1.0.11 192.168.2.0 0.255.255.255.
Thanks, :-)
sundar.palaniappan Thu, 07/05/2007 - 14:32
Access list names are case sensitive. Thus the router thinks these are two different access lists. I am not sure if I understood your requirement correctly but if you want to remove the first access list then all you have to do is to configure 'no ip access-list extended Policy-NAT'. This would remove the erroneously configured access list.
If you have a different requirement please clarify the same.
Sundar
Steven.Sanchez Thu, 07/05/2007 - 19:26
There is a bunch of ways to do it but this should work.
no permit ip host 10.1.0.11 192.0.0.0 0.0.255.255.255
end
royalblues Thu, 07/05/2007 - 20:42
Friend,
First let us know which is the active access-list in your configuration. This could either be a part of some policy or even applied directly to the interface with the help pf access-group statements.
Once you have that confirmation, you can edit the access-list as said by the previous poster and delete the other one.
Narayan
