Dual MSFC , SRM standby keeps going into "Status other"
Jul 5th, 2007
  • Green, 3000 points or more
Dont know what would be causing this issue, currently have a 6506 switch with dual sups, switch configured as SRM , I upgraded the code on both the switch and the routers to be
exact versions, when it was firts install monsth ago the secondary sup and MFSCs were good in stanby. Noticed a week ago the stanby router in the "status other". I reseted module 2 to notice secondary sup and MSFC with a "Status standby" , checked the logs and all looked ok, show redundancy info were enabled after the module was rebooted. Now 6 days later the standby MSFC is back into "state other".
Would this be a bug of some type, I could not find one ? or is there any configuration tunning I should look into for SRM implementation. Attached logs
Thank you all
Jorge
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Thu, 07/05/2007 - 17:15
thanks for the resource link.. will look into it..
Jorge
