857W Unable to allocate memory, etc
Jul 5th, 2007
Among other things, I am getting memory fragmentation errors, unable to allocate memory errors, unable to increase chunk size errors, etc.
We are also have extremely high usage (no one else is using the connection)
Our WLAN clients can't see each other as well.
I am at a loss.
Could someone have a look at our config file to see if there is anything wrong with the setup.
Jason
paolo bevilacqua Thu, 07/05/2007 - 17:24
  • Hall of Fame,
    Founding Member
Which IOS version are you using ?
jasonlilburn Thu, 07/05/2007 - 18:04
We are using 12.4(6)T5, which came with the router
Jason
paolo bevilacqua Fri, 07/06/2007 - 02:50
  • Hall of Fame,
    Founding Member
can you upgrade to 12.4(11)T2 that now has LD status and is what I use at home without problems. You will need a a support contract to access CCO download, ask you reseller about.
After that if still problems pls ask here but also with the same contract you can ask TAC for support or replacement if proved defective.
