a controller with the WLAN locked
Jul 5th, 2007
We have inherited a wireless network with 2000 & 4000 controllers. One of the controller has WLAN locked, so when users are attempting to login to this wireless network, they get a prompt, saying ?This network access needs a key to be authenticated; to connect to this WLAN?
I have looked up & down the controller config, but can;t find a place where I would unlock that WLAN. Can anyone please point me to where this setting is on the controller?
Thanks.
_ greg
john.preves Fri, 07/06/2007 - 15:28
Unless you know the key, you are probably hosed.
Remove it (the WLAN) and rebuild it.
I would build the second one first and test it. And then get rid of the other one.
axfalk Sun, 07/08/2007 - 10:16
Thanks for your response.
The wlan appears with the padlock next to it. We have layer 2 security set to 802.x on the controller and 802.11 data encryption to "wep". Is the padlock the result of enabling layer 2 security or setting the 802.11 data encryption to "wep"?
Thanks again...
