can't login to fwsm from the switch
Jul 5th, 2007
I was trying to configure a fwsm on catalyst 6500 running native IOS. FWSM running latest 3.2.1 code. I remembered that I have access-group in PermitAll outside and access-group out PermitAll outside applied. Also ssh is permitted from my workstation. Now I can ping the management IP, but not able to ssh into it, ever worse, console in is also denied. Please give some suggestions.
test#session slot 2 processor 1
The default escape character is Ctrl-^, then x.
You can also type 'exit' at the remote prompt to end the session
Trying 127.0.0.21 ...
% Connection refused by remote host
shivlu jain Thu, 07/05/2007 - 20:18
  • Silver, 250 points or more
hi
Please check the module status with
show module
.shivlu
sding2006 Fri, 07/06/2007 - 04:26
It turns out that only one console connection is permitted. I had another console connection.
Thanks.
sding2006 Fri, 07/06/2007 - 04:45
Sorry. My console connection refused again. So wired, I can ssh in the admin context, but not able to session slot 2 processor 1. Yes, the mod is up.
sding2006 Fri, 07/06/2007 - 05:54
Fixed. I did not save the config. Rebooted the module. reconfigured the admin context. Everything is now working.
