Duplicate Ip output on 3750 stack
chriswill
Here's my problem.
At present I have a 3750 stack running with several vlans configured.I get a cdp error stating I have a duplicate ip address which conflicts with my default gateway address. If I remove the vlan int address the cdp output changes to another
Vlan address. Is this a known problem with a 3750 ? Under the vlan interface I just have the ip address configured.
Any help would be appreciated
Chris
You mentioned you were getting CDP errors. The switches won't see each other via CDP while connected via the stack cable.
Let's see the output from typing
show cdp ne de
and
show mac-address-table | i 001b.5313.f5c6
Edison Ortiz
How you connected the switches ? With the stackable cable in the back or with copper/fiber connection in the front ?
If you go with the stackable cable in the back, you will only have a single management interface from all switches in the stack.
If you go with the copper/fiber connection in the front, you need to treat each switch independently.
They are connected as a stack with the stack cables. I gave each vlan an ip of .1 from that subnet. This is the address that is getting the duplicate meesage generated as below
Jul 6 03:23:42: %IP-4-DUPADDR: Duplicate address 10.62.164.1 on Vlan164, source
d by 001b.5313.f5c6
Chris
show cdp ne de
and
