BGP Vs Default Routes
Answered Question
Jul 5th, 2007
Would like to know what is the AD as mentioned above.
Cheers
Mansur
Correct Answer by guruprasadr about 9 years 7 months ago
HI Mansur,
Pls refer to the below Link for Definition of AD & for the table lists the administrative distance default values of the protocols that Cisco supports.
http://www.cisco.com/warp/public/105/admin_distance.html#topic2
PLS Rate if HELPS
Best Regards,
Guru Prasad R
Overall Rating: 4 (1 ratings)
