Configuration of tacacs and AAA accounting + PIX-515E
Answered Question
Jul 6th, 2007
Dear All;
I want to set accounting of PIX.
The equipment composition is as follows.
ACS SE : 4.1.1.23.5
PIX 515E : 7.0(6)
PIX setting is as follows.
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ host xx.xx.xx.xx
key xxxxx
aaa accounting command TACACS+
aaa accounting telnet console TACACS+
As a result, configuration parameter was written in ACS.
But User-Name is enable_15.(attached 1.jpg)
Is this a restriction??
Reiji
Correct Answer by parmsing about 9 years 6 months ago
Hi Reji,
Seems like we have command authorization configured on the pix. You must have enable authentication configured from the tacacs server then only we would get username is accounting, unlike IOS device pix does not send username to tacacs server, it would send enable_15 as username for all the users.
Configure the following command to make it work.
aaa authentication enable console tacacs+ LOCAL
-Parminder
Overall Rating: 5 (1 ratings)
Correct Answer
parmsing Fri, 07/06/2007 - 01:07
Hi Reji,
-Parminder
r.ogawa Fri, 07/06/2007 - 01:52
Thank you for your reply.
It succeeded when having immediately tested!!
Best Regards,
Reiji
