CAD 7.0 odbc connection to Logger problem
Jul 6th, 2007
Does anybody encountered with problem that I couldn't Sync Directory Services at CAD Administrator and as a result result there is no
list of agents at CAD Administrator?
david.macias Fri, 07/06/2007 - 02:33
Yes, I ran into the problem once, ensure that the account you're using is correct. Also, you might need to restart the CAD server(s).
david
LysetskyyS Fri, 07/06/2007 - 04:04
I'm using SQL auth - login: sa password: sa
but it's not working, even when i restarted server.
I tryed NT auth, but error occurs:"Error resetting service setting".
