Callmanager Express and CCIE Voice Lab
Jul 6th, 2007
Can anyone confirm whether Callmanager express is part of the Voice LAb.I have checked the Lab requirements etc and it is not specifically mentioned.
cheers
mark
Chris Deren Fri, 07/06/2007 - 05:48
Yes it is and always has been. Make sure you study it hard.
HTH, please rate all posts!
Chris
jhasen Sat, 09/29/2007 - 07:06
Do you have information about the tested version of CCME in the Voice LAB?
jhasen Sat, 09/29/2007 - 07:07
jhasen Sat, 09/29/2007 - 11:23
Thanks Chris,
And regarding to the VG248. Do you know what are the differences, if any between the vg248 and the vg224 (apart from the name and the number of ports)?
I am using the vg224 for my lab exam preparation and im not really sure of the equivalence in terms of features between both.
Thanks in advance
Chris Deren Sat, 09/29/2007 - 11:28
they are completely different, VG248 is SCCP GUI driven, where VG224 is IOS based and can be SCCP, H323, MGCP, SIP. configuration wise they are completely different, the good part is that VG248 is really easy.
Chris
jhasen Sat, 09/29/2007 - 11:31
Thanks again Chris.
So, if the vg248 is not a IOS based device... what about the software version used on the lab? 1.2, 1.3?
Thanks again in advance
