java.sql.timestamp variable type not available
Jul 6th, 2007
Problem Details: I am trying to return a value from a DB" database which
the DB Get step believes is a java.sql.timestamp type.
I have tried creating a variable of this type; there are none as default in the
drop down list and as per the script editor getting started guide, I have tried
entering the fully qualified java type (java.sql.timestamp) and the script
editor just rejects it, yet for example, if i enter java.math.BigDecimal, it
automatically converts the type to "BigDecimal" as soon as i move
away from this.
I see from documentation for CRS 2.2, this variable type was available. Has it been removed? If so, is there another way around this?
raynorris Fri, 07/06/2007 - 05:50
The problem was that java is case sensitive and if I enter java.sql.Timestamp (capital T) instead of java.sql.timestamp, it works fine.
Always a simple answer!
