C3080 IPSec SNMP
Jul 6th, 2007
Dear all,
Does someone kwow the OID and/or the MIB name giving, for an IPSec tunnel based on a E-VPN C3080, a tunnel Input and Output traffic ?
Here is an example of output informations I could find for a specific tunnel but it's not the generic MIB name I'm looking for :
SNMPv2-SMI::enterprises.3076.2.1.2.17.2.1.9.40 = Counter32: 130192120
SNMPv2-SMI::enterprises.3076.2.1.2.17.2.1.10.40 = Counter32: 6099528
Thanks a lot for your great help
Julien
David Stanford Fri, 07/06/2007 - 05:13
The above objects are from the ALTIGA-SESSION-STATS-MIB and are objects:
alActiveSessionOctetsSent
alActiveSessionOctetsRcvd
They are both very useful, but you could also look at:
CISCO-IPSEC-FLOW-MONITOR-MIB.my
CISCO-IPSEC-MIB.my
julienlarios Mon, 07/09/2007 - 00:49
Okay thanks, I'll look for it
Do those mibs can give me per tunnel statistics ?
julienlarios Thu, 07/12/2007 - 23:39
While testing I could get per tunnel/session informations like encryption details, but nothing about recv/drop/throttled packets.
Did I miss something ?
julienlarios Thu, 07/19/2007 - 08:16
I found counters dealing with total packets received or sent since session is up, but what I need to get is per tunnel live bandwidth utilization.
Does someone know how can I get these values with SNMP ?
Julien
klomper Tue, 10/02/2007 - 12:07
Julien,
Did you ever find this info? I need to get the same information about tunnel bandwidth utilzation. Any advice you have would be greatly appreciated.
Thanks.
Jeremy
julienlarios Wed, 10/03/2007 - 00:58
Jeremy,
I didn't get any additionnals informations, but the 2 OIDs I've mentionned are those we sucessfully use by now. I'm not directly in charge of setup, but I know there is a kind of index to consider with the OIDs. This index is linked with the tunnel ID.
Julien
